Cisco QM 8.5.2 LDAP integration error, 'Domain could not be validated'
I get the error 'Domain connection could not be validated' when i click OK with the below configuration under Enterprise settings in the QM Admin. It was working fine before. No change in the password, give the same error even with new user ID as well.
Base DN                - DC=ho,DC=COMPANY,DC=net
Domain Name      - COMPANY_domain
IP Address            - 10.10.5.1
Port                                        - 389
Display Name               - IPTAD
User Search Base - ou=FIM_MIG, ou=USERS, ou=COMPANY OU
Path                     - ou=FIM_MIG, ou=USERS, ou=COMPANY OU
Any help would be much appreciated.
Any body can give me a hand on this please !!
Have you made it ?
I got the same problem.
thanks,
Re: Cisco QM 8.5.2 LDAP integration error, 'Domain could not be
My issue is stil not received, i hav send a document to the system team to follow for the integration. The AD configuration for QM shud be very expicit or else integration will not work. I am attachin the doc here. Let me knw if that helps.
Hi, did you get this solved? I'm facing the same error.
We created another user account in the active directory. Also confirm that the user is in the same location as mentioned in the AD. There is nothing that we did in the QM to fix the issue
Thankyou, problem solved!
Glad to know the issue is resolved.
Please rate helpful posts.
1616
