Cisco real Time monitor + CUCM 8.5 + TCP UDP ports
I want use the CUCM 8.5 plugin "Real time monitor" , but i dont konw wich TCP/UDP port to open on the Firewall ?
(My laptop is in another VLAN than Vocie VLan , and The All Vlan are separated by A Cisco ASA Firewall).
Thanks in advance
Zarafa
I'd start by opening all the RTMT ports referenced here
Cisco Unified Communications Manager 8.5(1) TCP  and UDP Port Usage
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/port/8_5_1/portlist851.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
HiZarafa,
the link below is CUCM 7 but i think its same with cucm 8.x
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/port/7_0/CCM_7.0PortList.pdf
Unified CM
RTMT
1090, 1099 / TCP
418
