Community Member
Cisco Router 2901 - CME - Call Forward
I am currently running a Cisco Router 2901 with CME/CUE.
Is it possible to have the following:
Inbound call to a user. Caller reaches voicemail. They have the option to press "0" to be forwarded to another extension before having to leave a message.
Phil....
2 ACCEPTED SOLUTIONS
VIP Purple
Re: Cisco Router 2901 - CME - Call Forward
Yes, if you go to the CUE GUI > Voice Mail > Mailboxes and choose a mailbox, you will see the option "Zero Out (Operator Assistance)". You can set this to an extension to forward callers to when they press 0.
Hope this helps.
Brandon
Hall of Fame Super Red
Hey Phil,
Have you tried using the "zerooutnumber"?
SUMMARY STEPS
1. config t
2. voice mailbox owner name [size seconds]
3. description "text"
4. enable
5. expiration time days
6. greeting {alternate | standard}
7. mailboxsize seconds
8. messagesize seconds
9. tutorial
10. zerooutnumber "number"
11. end
12. exit
13. show voicemail {detail {mailbox | user} name | limits | mailboxes [idle days] | usage | users}
14. copy running-config startup-config
DETAILED STEPS
Command or Action
Purpose
Step 1
config t
Example:
se-10-0-0-0# config t
Enters configuration mode.
Step 2
Example:
se-10-0-0-0(config)# voice mailbox owner user3
se-10-0-0-0(config)# voice mailbox owner sales
Creates a mailbox for the name value and with storage size seconds value, and enters mailbox configuration mode.
This command maps the subscriber's name and extension (configured using the username command) to the voice mailbox.
Step 3
description "text"
Example:
se-10-0-0-0(config-mailbox)# description "User 3  mailbox"
(Optional) Enters a description of the mailbox. Use double quotes around the text.
Step 4
enable
Example:
se-10-0-0-0(config-mailbox)# enable
Activates the new mailbox or reactivates the disabled mailbox.
Step 5
Example:
se-10-0-0-0(config-mailbox)# expiration time 10
Sets the number of days for which messages are stored in the mailbox. The default is 30 days.
This value takes precedence over the system-wide expiration time.
Step 6
Example:
se-10-0-0-0(config-mailbox)# greeting standard
Specifies which greeting to use when a caller reaches the mailbox. The mailbox owner can record standard and alternate greetings from the telephone user interface (TUI). If the subscriber has not recorded any messages, the default recording is used.
Step 7
mailboxsize seconds
Example:
se-10-0-0-0(config-mailbox)# mailboxsize 300
Specifies the storage size of the mailbox, in seconds. This is the same as the size parameter mentioned in Step 2.
Step 8
messagesize seconds
Example:
se-10-0-0-0(config-mailbox)# messagesize 120
Specifies the maximum size of an incoming message, in seconds.
Step 9
tutorial
Example:
se-10-0-0-0(config-mailbox)# tutorial
Enables the mailbox tutorial program when the telephone subscriber logs in to the voice-mail system for the first time. The default is enabled. If the tutorial command is enabled after the mailbox is configured, the tutorial will start again but will confirm the subscriber's previous choices, rather than erasing them all. Use the no tutorial command to disable the tutorial.
Step 10
Example:
se-10-0-0-0(config-mailbox)# zerooutnumber "2100"
Specifies the extension where a caller is routed when the caller presses "0' to reach an operator after being transferred to a subscriber's mailbox.
Step 11
end
Example:
se-10-0-0-0(config-mailbox)# end
Exits mailbox configuration mode.
Step 12
exit
Example:
se-10-0-0-0(config)# exit
Exits configuration mode.
Step 13
show voicemail {detail {mailbox | user} name | limits | mailboxes [idle days]| usage | users}
Example:
se-10-0-0-0# show voicemail detail mailbox sales
se-10-0-0-0# show voicemail detail mailbox user1
se-10-0-0-0# show voicemail detail user user3
se-10-0-0-0# show voicemail limits
se-10-0-0-0# show voicemail mailboxes
se-10-0-0-0# show voicemail mailboxes idle 5
se-10-0-0-0# show voicemail usage
se-10-0-0-0# show voicemail users
Displays voice mailbox properties.
detail—Displays the details for a configured mailbox for the subscriber with the specified user ID. For a group mailbox, this is the name of the mailbox, not the owner of the mailbox. If a subscriber is an owner of a group mailbox, details for both the subscriber's personal and group mailboxes are displayed.
limits—Displays the default values for all mailboxes.
mailboxes—Displays all configured mailboxes and their current mailbox storage status. The idle parameter displays the mailboxes that have been inactive for at least the specified number of days.
usage—Displays how much of the system's voice-mail capacity has been used or configured.
users—Lists the local voice-mail subscribers.
Step 14
Example:
se-10-0-0-0# copy running-config startup-config
Copies the configuration changes to the startup configuration.
http://www.ciscosystems.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/administrator/AA_and_VM/3VMpara.html#wp1011652
Cheers!
Rob
VIP Purple
Hope this helps.
Brandon
Hey Phil,
SUMMARY STEPS
1. config t
4. enable
9. tutorial
11. end
12. exit
DETAILED STEPS
Command or Action
Purpose
Step 1
config t
Example:
Step 2
Example:
Step 3
description "text"
Example:
Step 4
enable
Example:
Step 5
Example:
Step 6
Example:
Step 7
mailboxsize seconds
Example:
Step 8
messagesize seconds
Example:
Step 9
tutorial
Example:
Step 10
Example:
Step 11
end
Example:
Step 12
exit
Example:
Step 13
Example:
Step 14
Example:
Cheers!
Rob
314
