Cisco router - Block UPDATE/REINVITE message
Hello.
I seem to have a problem with UPDATE messages being generated and this is causing my provider to respond with 481 message "Call Leg/Transaction" does not exist.
For this reason, I have tried disabling UPDATE messages but to no avail. I have managed to remove the field from the INVITE Header using Sip-Profiles, but that only applies to calls I generate.
My question is,is it possible to modify the INVITE Header for incoming calls using sip profiles? Or just blocking reinvites as a service? This is a simple matter which I have not found an answer by browsing the Cisco forums.
Platform is a AS5350XM, IOS version: 15.1
  voice service voip
     no ip address trusted authenticate
     allow-connections h323 to sip
     allow-connections sip to h323
     allow-connections sip to sip
     no supplementary-service sip moved-temporarily
     no supplementary-service sip refer
     supplementary-service media-renegotiate
     h323
     sip
      rel1xx disable
      header-passing sip-sip
      asserted-id pai
      sip-profiles 101
     voice class sip-profiles 101
      request INVITE sip-header P-Asserted-Identity modify "<sip:011(.*)" "<sip:+\1"
      request INVITE sip-header Diversion modify "<sip:011(.*)" "<sip:+\1"
      request INVITE sip-header P-Asserted-Identity modify "<sip:\+(.*)" "<sip:+\1"
      request INVITE sip-header Diversion modify "<sip:\+(.*)" "<sip:+\1"
      request REINVITE sip-header P-Asserted-Identity modify "<sip:011(.*)" "<sip:+\1"
      request REINVITE sip-header Diversion modify "<sip:011(.*)" "<sip:+\1"
      request REINVITE sip-header P-Asserted-Identity modify "<sip:\+(.*)" "<sip:+\1"
      request REINVITE sip-header Diversion modify "<sip:\+(.*)" "<sip:+\1"
      request REINVITE sip-header Allow-Header modify " UPDATE, " " "
      response 180 sip-header Allow-Header modify " UPDATE, " " "
      response 200 sip-header Allow-Header modify " UPDATE, " " "
      request ANY sip-header Allow-Header modify "UPDATE, " " "
      response ANY sip-header Allow-Header modify "UPDATE, " " "
      request INVITE sip-header Allow-Header modify ",UPDATE" " "
Thank you.
  • IP Telephony
445
