cisco router + gsm modem
is it possible to connect a GSM modem to the cisco router, so all calls from ip phones will go through this modem?
thank you
Hall of Fame Super Gold
Re: cisco router + gsm modem
You do not use a GSM modem for that, you use a so called "GSM box". There are with analog, ISDN, and ethernet interfaces, try to avoid the first type as long is possible.
I've never used this, but I heard about it:
http://www.zed-3.com/web/EN/Peripherals_GS8.htm
-- please remember to rate and mark answered helpful posts --
thank you very much,
our company tries to save money, so i have to find a solution, thats all internal phones call to the mobile phones via GSM modem or gateway.
This is interesting decision for me, for voip engineer, new experiens
so i'll try that
1127
