Community Member
Cisco Security Agent events
I'm getting the below errors in the Cisco Security Agent logs. I'm not sure if this is the result of a break-in attempt or a scan by the organization here. Anyone seen these before or can decipher?
11/27/2006 3:59:00 PM: The process 'C:\WINNT\system32\inetsrv\inetinfo.exe' (as user NT AUTHORITY\SYSTEM) attempted to receive the data '/<Rejected-By-UrlScan>?~/scripts/..%c1%8s../winnt/system32/cmd.exe'. The operation was denied.
11/27/2006 3:59:00 PM: The process 'C:\WINNT\system32\inetsrv\inetinfo.exe' (as user NT AUTHORITY\SYSTEM) attempted to receive the data '/<Rejected-By-UrlScan>?~/scripts/..%c0%qf../winnt/system32/cmd.exe'. The operation was denied.
11/27/2006 3:59:00 PM: The process 'C:\WINNT\system32\inetsrv\inetinfo.exe' (as user NT AUTHORITY\SYSTEM) attempted to receive the data '/<Rejected-By-UrlScan>?~/scripts/..%c0%9v../winnt/system32/cmd.exe'. The operation was denied.
11/27/2006 3:59:00 PM: The process 'C:\WINNT\system32\inetsrv\inetinfo.exe' (as user NT AUTHORITY\SYSTEM) attempted to receive the data '/<Rejected-By-UrlScan>?~/scripts/..%c1%1c../winnt/system32/cmd.exe'. The operation was denied.
11/27/2006 3:59:00 PM: The process 'C:\WINNT\system32\inetsrv\inetinfo.exe' (as user NT AUTHORITY\SYSTEM) attempted to receive the data '/<Rejected-By-UrlScan>?~/scripts/..%255c../winnt/system32/cmd.exe'. The operation was denied.
11/27/2006 3:59:00 PM: The process 'C:\WINNT\system32\inetsrv\inetinfo.exe' (as user NT AUTHORITY\SYSTEM) attempted to receive the data '/<Rejected-By-UrlScan>?~/scripts/iisadmin/bdir.htr'. The operation was denied.
11/27/2006 3:59:00 PM: The process 'C:\WINNT\system32\inetsrv\inetinfo.exe' (as user NT AUTHORITY\SYSTEM) attempted to receive the data '/PDG_Cart/shopper.conf'. The operation was denied.
11/27/2006 3:59:00 PM: The process 'C:\WINNT\system32\inetsrv\inetinfo.exe' (as user NT AUTHORITY\SYSTEM) attempted to receive the data '/_vti_pvt/authors.pwd'. The operation was denied.
11/27/2006 3:59:00 PM: The process 'C:\WINNT\system32\inetsrv\inetinfo.exe' (as user NT AUTHORITY\SYSTEM) attempted to receive the data '/./.././.././.././winnt/win.ini'. The operation was denied.
11/27/2006 3:59:00 PM: The process 'C:\WINNT\system32\inetsrv\inetinfo.exe' (as user NT AUTHORITY\SYSTEM) attempted to receive the data '/./.././.././.././windows/win.ini'. The operation was denied.
Re: Cisco Security Agent events
On which plataform are you running the CSA? Unity, CCM, etc?
There are some bugs from CSA with Unity, when you search a user with some characters like [ CSA block the search, etc.
I recommend you to upgrade the CSA to the latest version.
Community Member
These errors are seen on three CallManager servers, though, not on the Unity servers. Each of two Subscribers and the Publisher are seeing similar log events.
Community Member
These are three Cisco MCS 7835 CallManager servers running 4.1(3)
218
