Cisco SIP Phone 9971 will not register on CME 8.6
I'm trying to configure a  Cisco SIP Phone 9971,
but it won't register on CME 8.6, which is running on a 2811
The Phone shows this error message: Phone Not Registered.
And when I check the the Status Messages in the Phone, I see the following:
VPN Error: vpn is not configured
Actually, it shows all these 4 messages in a constant Loop:
12:01:59a SEP189C5DB6BD09.cnf.xml (TFTP)
12:01:59a No Trust List instaled
12:01:59a Updating Trust list
12:02:00a VPN Error: VPN is not Configured
It seems that this VPN Error is keeping the Phone from registering.
This is repeated for ever and the Phone never registers; at least that's what it appears.
However, when I do a sh voice register pool, I get the following:
C2811#sh voice register pool  1
Pool Tag 1
Config:
  Mac address is 189C.5DB6.BD09
  Type is 9971
  Number list 1 : DN 1
  Proxy Ip address is 0.0.0.0
  Current Phone load version is Cisco-CP9971/9.4.1
  DTMF Relay is enabled, rtp-nte
  Call Waiting is enabled
  DnD is disabled
  Video is enabled
  Camera is enabled
  Busy trigger per button value is 0
  call-forward b2bua busy 68600
  keep-conference is enabled
  registration expires timer max is 3600 and min is 120
  username adm password adm
  kpml signal is enabled
  Lpcor Type is none
  blf call list is enabled
  Transport type is udp
  service-control mechanism is supported
  registration Call ID is 189c5db6-bd090005-24ea26fa-655d3e3a@172.35.140.12
  Registration method: per line
  Privacy feature is not configured.
  Privacy button is disabled
  active primary line is: 1010
  contact IP address: 172.35.140.12 port 5060
  Phone SIS Version:  6.0.2
  GW SIS Version:  1.0.0
Dialpeers created:
Dial-peers for Pool 1:
dial-peer voice 40001 voip
destination-pattern 1010
session target ipv4:172.35.140.12:5060
session protocol sipv2
dtmf-relay rtp-nte
digit collect kpml
codec  g711ulaw bytes 160
no vad
  call-fwd-busy        68600
  after-hours-exempt   FALSE
Statistics:
  Active registrations  : 4
  Total SIP phones registered: 1
  Total Registration Statistics
    Registration requests  : 4
    Registration success   : 4
    Registration failed    : 0
    unRegister requests    : 0
    unRegister success     : 0
    unRegister failed      : 0
    Attempts to register
           after last unregister : 0
    Last register request time   : 18:11:43.551 UTC Mon Feb 24 2014
    Last unregister request time :
    Register success time        : 18:11:43.551 UTC Mon Feb 24 2014
    Unregister success time      :
C2811#
This sh voice register pool  seems to indicate that the Phone has actually registered.
But I still get the  Phone Not Registered   message on the screen!
I did some Debugs and they also seem to indicate that the Phone has indeed registered:
Feb 24 18:01:12.399: VOICE_REG_POOL: Creating param container for dial-peer 4000
1.VOICE_REG_POOL pool->tag(1), dn->tag(1), submask(1)
VOICE_REG_POOL pool_tag(1), dn_tag(1)
Feb 24 18:01:12.399: VOICE_REG_POOL: Created dial-peer entry of type 0
Feb 24 18:01:12.399: VOICE_REG_POOL: Registration successful for 1010, registration id is 1
Feb 24 18:01:12.411: VOICE_REG_POOL: Contact matches pool 1 number list 1
Feb 24 18:01:12.411: VOICE_REG_POOL: GW SIS: X-cisco-cme-sis-1.0.0
Feb 24 18:01:12.411: VOICE REGISTER POOL-1 has registered.
                               Name:SEP189C5DB6BD09 IP:172.35.140.12  DeviceType:Phone
So frankly, I have no idea why the Phone keeps showing the Phone Not Registered message.
I'm pasting the Router's config.
I hope somebody is able to point me in the right direction.
Here is the config.  Thank you!
C2811#sh run
Building configuration...
version 15.1
hostname C2811
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 172.25.140.1 172.25.140.10
ip dhcp excluded-address 172.35.140.1 172.35.140.10
ip dhcp pool Data
network 172.25.140.0 255.255.255.0
default-router 172.25.140.1
option 150 ip 172.25.140.1
dns-server 172.25.140.1
ip dhcp pool Voice
network 172.35.140.0 255.255.255.0
default-router 172.35.140.1
option 150 ip 172.35.140.1
dns-server 172.35.140.1
no ip domain lookup
no ipv6 cef
voice service voip
allow-connections sip to sip
sip
  registrar server expires max 3600 min 120
voice register global
mode cme
source-address 172.25.140.1 port 5060
max-dn 40
max-pool 42
load 9971 sip9971.9-4-1-9.loads
authenticate register
authenticate realm cisco
tftp-path flash:
create profile sync 0004820400584603
voice register dn  1
number 1010
allow watch
name Phone10
label Phone10
mwi
id mac 189C.5DB6.BD09
type 9971
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
no vad
camera
video
voice-card 0
crypto pki trustpoint TP-self-signed-1879153754
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1879153754
revocation-check none
rsakeypair TP-self-signed-1879153754
crypto pki certificate chain TP-self-signed-1879153754
certificate self-signed 01
(details ommited)
license udi pid CISCO2811 sn FTX1146A44H
username admin privilege 15 password 0 admin
redundancy
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.25
description Data VLAN
encapsulation dot1Q 25
ip address 172.25.140.1 255.255.255.0
interface FastEthernet0/0.35
description Voice VLAN
encapsulation dot1Q 35
ip address 172.35.140.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
tftp-server flash:P00308010200.bin
tftp-server flash:P00308010200.sbn
tftp-server flash:P00308010200.sb2
tftp-server flash:P00308010200.loads
tftp-server flash:SCCP42.9-3-1SR3-1S.loads
tftp-server flash:apps42.9-3-1ES19.sbn
tftp-server flash:cnu42.9-3-1ES19.sbn
tftp-server flash:cvm42sccp.9-3-1ES19.sbn
tftp-server flash:dsp42.9-3-1ES19.sbn
tftp-server flash:jar42sccp.9-3-1ES19.sbn
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:SCCP45.9-3-1SR3-1S.loads
tftp-server flash:apps45.9-3-1ES19.sbn
tftp-server flash:cnu45.9-3-1ES19.sbn
tftp-server flash:cvm45sccp.9-3-1ES19.sbn
tftp-server flash:dsp45.9-3-1ES19.sbn
tftp-server flash:jar45sccp.9-3-1ES19.sbn
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:/Ringtones/Ringlist.xml alias Ringlist.xml
tftp-server flash:/Ringtones/DistinctiveRingList.xml alias DistinctiveRingList.x
ml
tftp-server flash:sip9971.9-4-1-9.loads
tftp-server flash:kern9971.9-4-1-9.sebn
tftp-server flash:rootfs9971.9-4-1-9.sebn
tftp-server flash:dkern9971.100609R2-9-4-1-9.sebn
tftp-server flash:sboot9971.031610R1-9-4-1-9.sebn
tftp-server flash:skern9971.022809R2-9-4-1-9.sebn
tftp-server flash:/g4-tones.xml alias United_States/g4-tones.xml
tftp-server flash:/gd-sip.jar alias English_United_States/gd-sip.jar
control-plane
mgcp profile default
telephony-service
max-ephones 24
max-dn 48
ip source-address 172.25.140.1 port 2000
cnf-file location flash:
load 7960-7940 P00308010200
load 7942 SCCP42.9-3-1SR3-1S.loads
load 7945 SCCP45.9-3-1SR3-1S.loads
load 7962 SCCP42.9-3-1SR3-1S.loads
load 7965 SCCP45.9-3-1SR3-1S.loads
max-conferences 8 gain -6
dn-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Feb 11 2014 07:18:32
ephone-dn  1
number 1001
description Phone 1
name Phone 1
hold-alert 30 originator
ephone-dn  2
number 1002
description Phone 2
name Phone 2
ephone-dn  3
number 1003
description Phone 3
name Phone 3
ephone  1
device-security-mode none
mac-address 001C.58FB.6E0F
button  1:1
ephone  2
mac-address 0014.A981.7F8A
button  1:2
ephone  3
mac-address 0006.5356.A4B8
button  1:3
alias exec con conf t
alias exec sib show ip int brief
alias exec srb show run | b
alias exec sri show run int
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
ntp master 1
end
C2811#
I was wondering if you ever
I was wondering if you ever figured this out?  I can't seem to get any Cisco phone to register 7941 or 7960
VPN is not Configured prints
VPN is not Configured prints on all phones now with the built-in VPN client if VPN isn't configured.  That's normal and is just cosmetic.  That should not be causing your registration issues.
783
