Cisco SIP Phone : Lost password
I have 2 Cisco Phone (7905G) with sip firmware.
I lost the configuration password. So I can't change network settings.
Is there a way to do a factory default reset ?
Thanx,
Bastien.
Silver
Re: Cisco SIP Phone : Lost password
Restoring Factory Default Settings Perform the following steps to restore factory default settings when you forget the password.
Press *, 0, and the 4 softkey simultaneously. The manufacturing test-option screen appears.
Type 322873738# and press *.
Press *, 0, and the 4 softkey again, or power-cycle the phone. You return to normal operation.
Alternatively - and probably easier,
You can register the phone with SCCP, and then switch it back over to SIP. If you have a CUCM 5/6 this is probably the easiest option. If this is standalone you'll be better off with the factory reset.
340
