Community Member
Cisco SPA525G and uCCM 7
It is possible to get this phone working on uCCM Version 7? I got into the WebUI interface of the phone, and changed from SIP to SCCP and got the phone generating the SEP device name, however, still can't get to register on the CCM...
Any hints will be appreciate..
1 REPLY
Re: Cisco SPA525G and uCCM 7
The phone really does not runs SCCP, it runs SPCP which is not compatible with CUCM but only with UC500.
These phones are designed to integrate with UC500 only on SPCP mode and SIP for third party Call Agents.
Cisco SPA 525G 5-Line IP Phone with Color  Display: Cisco Small Business Pro IP Phones
• Supports both SIP with SPA9000 or leading third  party call control platforms and SPCP Protocols with Cisco Unified  Communication 500 Series
You may try them with SIP if you like.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
210
