Cisco Syslog + Billing Software
Hi all,
I am configuring a billing software to work with Cisco CME 8.8.
On the CME side, i enabled syslog logging using the following commands:
gw-accounting syslog
logging facility syslog
logging ip_address
logging trap notifications
I received the following log after a call:
Jan  5 18:21:49.817: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId EDD6080E370011E18A2BC77F1C86C06D, SetupTime 18:21:34.257 UTC Thu Jan 5 2012, PeerAddress 1023, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 18:21:35.697 UTC Thu Jan 5 2012, DisconnectTime 18:21:49.817 UTC Thu Jan 5 2012, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Jan  5 18:21:49.817: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:01/05/2012 18:21:34.254,cgn:3333,cdn:1023,frs:0,fid:1013,fcid:EDD6080E370011E18A2BC77F1C86C06D,legID:455,bguid:EDD6080E370011E18A2BC77F1C86C06D
CME-TP-ALJADIDA#
Jan  5 18:21:49.817: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId EDD6080E370011E18A2BC77F1C86C06D, SetupTime 18:21:32.757 UTC Thu Jan 5 2012, PeerAddress 3333, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 18:21:35.697 UTC Thu Jan 5 2012, DisconnectTime 18:21:49.817 UTC Thu Jan 5 2012, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Jan  5 18:21:49.817: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:01/05/2012 18:21:32.758,cgn:3333,cdn:,frs:0,fid:1012,fcid:EDD6080E370011E18A2BC77F1C86C06D,legID:454,bguid:EDD6080E370011E18A2BC77F1C86C06D
CME-TP-ALJADIDA#
The billing software treats this call as an error, after some debugging i found that the cause is the
TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0 , very stange with a 14 seconds call.
Any help will be appreciated.
Re: Cisco Syslog + Billing Software
Hi Yossef,
I would recommend that you check this Cisco document for setting up CDR's on UCME, note RADIUS or FTP provide the full CDR header information, Syslog does not.
http://www.cisco.com/en/US/docs/ios/voice/cdr/developer/guide/cdrover.html
Table 1 Accounting Methods Comparison
Accounting Method
Benefits
Restrictions
File Accounting
FTP servers are inexpensive and easy to setup
Commonly available applications like Microsoft Excel can be used to parse and generate reports
Supports all CDR fields
Compact CDR format option
No support for real-time applications
RADIUS
RADIUS is an AAA server, you get AAA services along with the CDR collection
Supports real-time applications
Retries built-in
RADIUS servers are generally more expensive than other methods
syslog
Less expensive than RADIUS
One syslog server can support both error monitoring and CDRs
Limited attributes supported
No retries built-in (UDP based)
If many debugs are enabled, server performance might be impacted
We have a RADIUS server built into our TIM Plus and Enterprise software if you wanted to test that with your router. It's also certified compatible by Cisco.
For more info see www.tri-line.com/cisco to register for a free trial.
We also can sync with Cisco UCM and UCME to bulk load all your users and handsets.
Cisco UCME sync:
TIM Plus overview:
Thank you Jamie for your answer,
The TIM software seems to be very useful but in my case ,the customer has already another third party billing software who works using cisco syslog.
I still have the same problem , the CDR of a successful call shows 0 bytes so the billing software cannot process the record.
Any ideas???
Hi Yossef,
Has the provider of the billing software provided any spec of the requirements they need for Syslog to work with the software?
Is the software IVT certified with Cisco UCME?
Currently only two Cisco development partners are IVT certified, our self (Tri-Line) included http://developer.cisco.com/web/partner/search?technologyIds=a0G40000001YkC7EAK&subTechnologyIds=a0K40000001fRBOEA2&technologyProductIds=a0I40000000ycyjEAA&partnerProductFamilies=Call Accounting and Billing&certified=Yes&onCiscoPriceList=All&portfolio...
Our TIM products have Syslog built into them, so no need for any 3rd party software.
I'm not sure what the billing software is that your customer is using, however see this Cisco guide for setting up Syslog http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/srnd/design/guide/managcme.html#wp1076063
Commands in summary:
Enable the Cisco IOS logging capability to log all the syslog events into the buffer on the Cisco Unified CME router, or send the syslog messages to a syslog server for offline management, as shown in the following example.
Telephony-service#(config)# service timestamps log datetime msec localtime
Telephony-service #(config)# aaa new-model
Telephony-service #(config)# aaa authentication login default none
Telephony-service #(config)# aaa accounting connection H.323 start-stop radius
Telephony-service #(config)# gw-accounting syslog
Telephony-service #(config)# logging 10.10.10.1
10.10.10.1 is the ip address of syslog server, multiple servers might also be
  specified
Dont forget to rate useful posts.
648
