Cisco TAC support for UC540
Is cisco UC540 is supported by TAC ? Any TAC support available for UC540W-FXO-K9
In TAC I can see UC520 but not sure TAC support UC540.
Pls. clarify.
Rgds
Rajesh
Hall of Fame Super Gold
UC500 has support from either small business organization, or Cisco Enterprise TAC with smartnet contract.
Dear Paolo
Can we open the TAC case for UC540 same as normal TAC case we open for Cisco Router/Firewall?
Or it is separate procedure?
Rgds
Rajesh
Same procedure with support contract.
I have UC540 and running 12.4, SPA525G2 phones are not supported in this.
I want to upgrade to UC540-8.6.0.zip, I have already downloaded the file.(upgrade from 12.4 to 15.1.4M4)
Can anyone suggest how to upgrade UC540 and is there any upgrade license required for upgradation?
254464K Flash memory is sufficient for upgrade ?
Also phone has version 7.4.8, will it upgrade new firmware after upgradation directly.
Pls. provide me suggestion and feedback.
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 12.4(24)SB, RELEASE SOFTWARE (fc1)
Cisco UC540W-FXO-K9 (MPC8358) processor (revision 0x100) with 249856K/12288K bytes of memory.
14 User Licenses
10 FastEthernet interfaces
2 terminal lines
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 802.11 Radio
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
254464K bytes of ATA CompactFlash (Read/Write)
Rgds
Rajesh
There are no license or memory restriction for the update you mentioned.
304
