cisco telephony license capacity management
   Are there any cool tools out there that will allow me to perform license capacity management for my Call manager and unity connection. I am looking for something that will provide graphs and display a trend.
Thank you
  • IP Telephony
On 9.X ELM is the one place for all that, in previous versions, it's per product
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Which version are you using.
Enterprise License Manager which was introduced with 9.0 shows useful info wrt licenses but does not do trending afaik.
We are using 8.6. I need something that allows trending.
103
