Cisco Telepresence Licenses
Hello all,
We are in testing phase & integrated virtual Telepresence 4.0, virtual Conductor XC2.3 with CUCM 8.6.2 for Adhoc & Meetme conference.
We have end point SX 20 registered into CUCM. When we dial meet number from SX 20 its keep dialing & not connecting or answered by telepresnce.
I just noticed that there are no screen licenses are installed into TP Server.
Is it mandatory to have screen license to make conference calls ?
Can i apply for demo licenses file ?
Conie
1 ACCEPTED SOLUTION
Yes, you will need screen
Yes, you will need screen licenses. As far as demo, I havent seen but worth checking with licensing@cisco.com
Please rate useful posts.
Hi George,Thank your for
Hi George,
Thank your for reply.
I checked with licensing team, they said there is no temp or demo license for this product.
Conie
Reach your SE/AM they might
Reach your SE/AM they might be able to help with a temporary license.
java
if this helps, please rate
www.cisco.com/go/pdi
 Thanks Jaime, for suggestion
Thanks Jaime, for suggestion.
Will do that.
Conie
VIP Purple
Hi Conie, I was refering the
Hi Conie,
I was refering the ordering guide which says
Cisco TelePresence Server Licensing
Cisco TelePresence Server is licensed by the number of screens, which depends on the number of simultaneous parties in conference, and presentation content resolution. Each screen license enables one 1080p participant to  connect with up to 720p15 content sharing.
For example, two Cisco TelePresence Server screen licenses can support a conference of the following combination of endpoints:
● Two 1080p30 resolution endpoints
● Four 720p30 resolution endpoints
● Eight 480p30 resolution endpoints
● Sixteen 360p30 resolution endpoints
There are variations in the supported number of parties in a conference based on presentation content resolution, audio type, and different types of endpoints.
As suggested by Jaime, u can reach SE/AM for more details.
regds,
aman
Hello,Got demo license with
Got demo license with the help of SE :)
Conie
VIP Purple
[+5] to Jaime. thanks for
[+5] to Jaime.
thanks for update.
regds,
aman
Yes aman, U r right.
Yes aman, U r right. I been went through the same link. Regards Conie
158
