Community Member
Cisco UC and Microsoft lycn Integration compatibility.
Hi Guys,
I have a Callmanager ver 6.0 and i want to integrate with icrosoft lnc 2010.
Please is this compatible?
1 REPLY
This integration is validated by Cisco Interop team & such tested/supported integrations are documented at " Cisco Interoperability Portal ". As per the documents listed on the portal, MS Lync 2010 is only tested with CUCM 8.5 & not with earlier versions. Therefore it's safe to presume that MS Lync 2010 will be supported only with CUCM 8.5 & later.
Cisco Interoperability Portal can be found here http://www.cisco.com/en/US/solutions/ns340/ns414/ns728/networking_solutions_products_genericcontent0900aecd805b561d.html
It has the MS Lync 2010 & CUCM Integration documents there.
Pls rate the post if it helps.
GP.
372
