Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Cisco UC Integration for Microsoft Lync 9.2.(5)
i have CUCM cluster VER. 8.6.2 , and now trying to intall CUCILync VER. 9.2.(5) to  integrate with Lync 2010
after installation the UC inegration and run Microsoft lync it opens two windows one for Lync and another one for UC integration and don't open on one window with CUCILync bar in the bottom of the interface ,
any one can clrifay if it is new interface or i have a problem ?
Hall of Fame Super Silver
This is how CUCI-Lync 9.X works, separate application, no longer attached to the Lync client.  As bad as it sounds this is how Cisco made it work after simply replacing previous CUCI-Lync with stripped version of Jabber in version 9.  Sorry.
HTH,
Chris
Re: Cisco UC Integration for Microsoft Lync 9.2.(5)
I have a problem with click to call , it is not working , should I do any configuration to make it work ?
while i set cucilync as deskphone the video call don't starts , it statrt audio call only ,
but while the i set as soft phone the video call starts normal ,
504
