Cisco UC560-FXO, line occupying issue
Dear all, I need some help very urgently.
we have Cisco UC560-fxo-k9, it has been installed since last 1 year and we are facing busy tone issue because of fxo lines are getting occupied even after the phone is on-hook........... re-configuration has been done couple of times but could not resolve this.
it goes like this.....
when a call comes or goes out of PBX, and if is disconnected from any one end, we can notice the call is still active in PBX as the fxo line light blinks for next 1-2 mins. and after some time it becomes available so that busy line tone also ends.
waiting for your all kind and prompt response.
Hi.Can you please post your
Hi.
Can you please post your UC560 configuration?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Thanks for responding, please
Thanks for responding, please check the file attached.
your support is appreciated.
Hi.On a voice port try no
Hi.
On a voice port try no battery reversal and supervisory disconnect dual dualtone mid-call and see if it brings the desired effect
Carlo
hi, I did all the changes you
hi,
I did all the changes you asked to make but it haven't made any difference please let me know the reason for such cause, i think there is no any hardware defect in box,,,,,,please let me know how I can proceed further.
thanks
Hi.Please activate a debug
Hi.
Please activate a debug vpm all during a call and post the output.
Carlo
hi carlo..... I will do this
hi carlo..... I will do this debugging and post you once I did it.
hi,this is to inform you that
hi,
this is to inform you that I enabled the debug commands which were specified above but strangely I couldn't get any output on the screen, further I tried some other debug commands but was vain.
secondary, I made some observation of FXO ports live on UC560, here I came to know the FXO line on which the call is active is blinking, later when the call is handed off the light still remains on FXO port for around 40 secs-1 mins.
That means the line is still active in UC560, so based on the above attached file of configuration, can I get the idea why is such behavior in device.
further also wants to make one thing open that the supervisory custom tone which runs in this telephony system was defined by the previous implementation team. (supervisory custom tone--test).
why do you have this ,
 supervisory custom-cptone TEST
timing sup-disconnect 60
hi javelkur,this initial
hi javelkur,
this initial configuration was done by another team and later I came here and since I came here this problem was existing and continued even after its re-configuration.
can you remove thosesh/no sh
sh/no sh the port and enable deb vpm sig and deb voip ccapi inout
send the logs after making a call with the call details
78
