Community Member
Cisco UCCX NIC card supported
Did anyone know is the NIC card below is supported for Cisco UCCX agent voice recording?
1. Broadcom Netxtreme 57xx Gigabit Controller
2. Realtek PCIe GBE Family Controller
thank you.
1 ACCEPTED SOLUTION
Have a look at this writeup, it has a nice test procedure you can follow to determine if your NIC will work in the UCCX environment for silent monitoring.
http://www.cisco.com/en/US/products/sw/custcosw/ps427/products_tech_note09186a00801f42f9.shtml
"During extensive internal testing Cisco identified that some Ethernet NIC card drivers available are not capable of pre-processing Ethernet frames that have an IP packet encapsulated in a VLAN frame. The NIC card driver discards the Ethernet frame altogether if the IP packet is encapsulated in an 802.1Q frame. Some vendors can provide a configuration setting that allows their NIC card driver to forward VLAN traffic to the TCP/IP stack."
"If an agent desktop NIC card driver discards VLAN traffic, the silent monitor subsystem on that desktop is not able to collect and forward voice packets to the supervisor workstation and silent monitor does not function properly. Cisco has developed a procedure to determine whether a particular Ethernet NIC card driver works with CTI OS Silent Monitor. The procedure is described in the Test Procedure section."
Community Member
Did you ever get any information for your Realtek PCIe GBE Family Controller?
I am having the same problem.
Community Member
Re: Cisco UCCX NIC card supported
Hi richdog,
So sad, I also failed to do it due to this kind of nic is not supported by Cisco monitoring.
The original NIC's we used didnt work either so I went down to Best Buy and bought a few 8 dollar network cards that were so dumb they didnt understand what dot1q was and they worked like a champ.
1215
