Cisco UCM 5: CDR reports has stopped working?
This is a strange issue and need guidance on how I can troubleshoot this issue.
I enabled CDR Analysis and Reporting capabilities on Cisco UCM 5.1.
It has collected call details and reports like seeing call activity for a particular directory number for over a year.
Now it won't generate any new reports.
It generates "Error Code: 10021 - There are no matching records"
I haven't logged in for 3 months, so I don't know what the issue could be.
Is there something I can do and look at to fix this problem?
Thank you!
Red
Re: Cisco UCM 5: CDR reports has stopped working?
We'll need CAR scheduler logs to troubleshoot.
Michael
http://htluo.blogspot.com
Thanks for reply Michael.
How do I obtain the CAR scheduler logos?
Thank you!
I had this issue last week, it was caused by too many CDR's.
You can check CAR -> System -> Database -> Manual Purge -> Table information.
If you count all these, you should not exceed 2 million records.
I did exceed this and altered the System -> Database Automatic Purge -> Min Age, which solved the issue.
Angelique
441
