09-10-2008 03:43 AM - edited 03-15-2019 01:10 PM
Hi!
I'll plan to buy UCM 7.0 Is it possible to install Unity/ContactCenter or other cisco telephony services on the server where UCM 7.0 was already installed or I should buy separate server for ContactCenter, Unity an so on?
Solved! Go to Solution.
09-10-2008 04:28 AM
Hi Alexander,
You must be thinking of Cisco Unified Communications Manager Business Edition. CUCMBE is indeed a CallManager co-resident with Unity Connection, and can be installed on the MCS7828 servers.
You can find more information here:
http://www.cisco.com/en/US/products/ps7273/tsd_products_support_series_home.html
Hope this helps.
Michael.
09-10-2008 03:51 AM
Alexander,
For the applications you have listed, you will need to buy separate servers for each.
Hope this helps.
Michael.
09-10-2008 04:07 AM
Hi Michael!
I hear that exist an aplication (Unity or IPCC(X) that I can install together with Callmanager. Is it thrue?
09-10-2008 04:28 AM
Hi Alexander,
Hope this helps.
Michael.
