Cisco UCM Upgrade log
I have a CUCM cluster with an active version of 6.1.4.2190-3 and an Inactive version of 6.1.2.1133-1.
Is there any way in CUCM to find out whenthe activer version, 6.14.2190-3 was applied (date / time stamp)?  Or what account was used to apply the upgrade?
Thanks in advance
1 ACCEPTED SOLUTION
Super Bronze
file tail install system-history.log
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
There's a record in the install log partition I think.
SSH to the server, then do :
file list install /
Or just retrieve all the Install logs from RTMT..
I think it's called system-history or something history... not near a CCM right now.
Bad news is that any upgrade must be initiated using a platform admin account - typically one of those gets created at install-time, and there remains only one! The 'end user' and 'app user' accounts you use on a daily basis for admin etc can't be used to install software.
Aaron
Please rate helpful posts..
Super Bronze
Aaron
226
