Cisco UCS 7 Call Handling based on time of day
Call to a DID I want to go to voice mail on RNA 8am to 5pm.  But 5pm to 8am I want to forward these calls to another number.  Where do I do this in UCS?  Can it be done?
1 ACCEPTED SOLUTION
Blue
Re: Cisco UCS 7 Call Handling based on time of day
Here is example for CUCM 6 but can be used for CUCM 7
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080a7bc96.shtml
Ronak patel
If this helps, please rate the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Configure schedules and then configure the std greeting for working hours and closed greeting for after-hours under the call handler.
If you have CUCM you can use TOD.
I assume you're referring to CUC, Cisco Unity Connection right???
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Actually no.  We use UCS 7 for PBX and with Exchange UM for voice mail.  I am wondering if within UCS I can specify forwarding based on time of day.  If know perhaps you know whether or not this is possible with MS UM?
In Cisco world, UCS refers to HW (virtualization servers)
Is it CUCM what you're talking about when you mention UCS??
If so, use TOD.
java
java
Haha - right CUCM.  Sorry I recently implemented UCS and have UCS on the brain.  Where do I find TOD?
Blue
Ronak patel
Great - that's it.  Thanks.
Hall of Fame Super Red
Thought you might enjoy this thread as well
It has a really awesome breakdown of ToD by fellow NetPro Bill Bell
as well as a fine catch by Java;
https://supportforums.cisco.com/message/3044337#3044337
Cheers!
Rob
"Everything is broken" - Bob Dylan
432
