Cisco UCS C200 M2 Server-HDD replacement
I need to replace HDD on UCS server which is in production for which down time is very difficult. Its having RAID-10 configured with 4 hardisks of 1 TB each. Can I do the hot sawp for the faulty hard disk or do I need to shut down the server and replace the HDD. Please find the screen shot of the server health for more info.
Thanks.
1 REPLY
Green
Look at this link:-
http://www.cisco.com/en/US/docs/unified_computing/ucs/c/hw/C200M1/install/replace.html#wp1130750
Installing Hard Drives or Solid State Drives
The qualified and supported part numbers for this component are subject to change over time. For the most up-to-date list of replaceable components, see the following URL and then scroll to Technical Specifications:
http://www.cisco.com/en/US/products/ps10493/products_data_sheets_list.html
Tip You do not have to shut down or power off the server to replace hard drives because they are hot pluggable.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
1044
