Cisco UCS C220 VMware ESXi Error Messages
I have two Cisco C220 M3 servers running VMware ESXi installed using the ISO file VMware-VMvisor-Installer-5.1.0.update02-1483097.x86_64.iso
The servers are used to host CUCM, Unity Connection, UCCX and a couple of Windows servers.
Both servers are reporting errors similar to that below:
Device naa.600605b008e189b01b689af4132a65b6 performance has deteriorated. I/O latency increased
from average value of 263 microseconds to 13460 microseconds.
The servers use local storage only.
Is this message anything to be worried about? - I have seen some suggestions that it is not and is just a cosmetic bug. Others suggest that it could indicate a hardware issue - possibly with the RAID controller.
I have to confess that I used the generic VMware ESXi install disk rather than the custom Cisco ISO so I guess it could be a driver issue.
Any suggestions on how to take this forward?
Aplogies for posting in the voice forum but I thought the post would be more likely to be read by people who deploy UCS C series devices within on-board storage than if I posted in the UCS forum
Everyone's tags (1)
Same issue here. Doesn't
Same issue here. Doesn't appear to coincide with any outages, but would like to know what the issue is regardless. Where is this mentioned as being only cosmetic?
Hello James,
Hello James,
I have the same issue. Did you resolve it?
Thank you!
Yordan Vichev
As far as I can remember it was an issue with the firmware on the RAID controller. I ran the UCS Host Update Utility and the issue did not recur.
James
Hi James,
Hi James,
Thanks for your answer! I will try!
Have a nice day!
Yordan
361
