Cisco Unified Business Att. Console Server VM Ware?
hbarrera2
guru's,
does cisco support CUBACS via VMWare?
cheers.
7 Replies 7
Jaime Valencia
no, requirements are here:
Cisco Unified Business Attendant Console
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps7046/ps7282/product_data_sheet0900aecd805e6a5f.html
VMWare is not a supported platform
java
if this helps, please rate
java
javalenc,
The doc gets the point across about a physical server or desktop pc,but if it is on vmware will TAC support it?
Thanks again.
NO
java
java
As you can see I was digging...thanks again!
So you have to deploy the CUBACS (Server app) on a seperate pc/server, thier is no way around this or an alternate installation method?
This means clients have to fork over a decent sized box just to support 1 little application?
To add, does thier have to be 1 CUBACS (Server) at each location of an Att console or can a centralized deployment model be used?
Thanks.
Hi Java,
If the Business attendant console is a rebaged ARC console how come ARC support the enterprise console in a virtual environment and cisco don't?
Also does the server have to be a standalone server or can you utilise a server with other applications on it?
Stafford
The CUBAC did not work out for our client, since you could not break out the CTI RP's and CTI Ports on the backend.
We had 3 seperate sites that wanted to stay seperate from an incoming call/ attendent perspective. So we moved forward with Arc Ent. which allowed us the flexibility we needed and as you mentioned above is supported on vmware.
Cheers.
