Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Cisco Unified Business Edition 6k ver 9.1 integration with Nortel CS1k
Customer's Current Site: It has Nortel CS1k
New Site: Factored Cisco Unifed Business Edition 6K ver9.1 with HA
Cisco Unifed Business Edition 6K ver9.1 has to be integrated with Nortel CS1k. Like to understand how this integration would take place?
  1. Do we need to setup a normal IP Trunk between the two from Business Edition
  2. Does the integration require a SIP Trunk with CUBE license on Cisco Voice Gateway
Also, like to know if Automatic Failover is supported from Business Edition 6k ver9.1 between two business Edition Servers in HA mode running CUCM and Unity Connection
Sumit
VIP Super Bronze
Re: Cisco Unified Business Edition 6k ver 9.1 integration with N
The link below details the integration.
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns784/1206769.pdf
You can read more about load balancing and design consideration on your business edition here
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/9x/callpros.html#wp1159144
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
No, no trunks or anything are required (unless you're building two separate 6K clusters, then yes)
Phones will failover as in any other deployment, if you configure a PUB and a SUB.
Are you familiar with the 6K??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
129
