Cisco Unified Call Manager 6.1 and VMware 4.1
JAYESH RAMAIYA
I am currently in the process of installing CUCM 6.1 on vmware so that we can test integration with AD. Im currently having problems installing installing the software. It boots up and but fails on the hard ware issues.
All our equipment is Dell and runs on Intel.
Are there any links or posts that you can assist with.
Thank you in advance.
Jay
Brett Fritzsch
Jayesh,
So the short of it is because 6.1 isnt supported on VMware.  The first version that is officially TAC supported on VMware is 8.0.2.  With that being said, for lab recreates and confirming you have successful backups, it can be advantageous to have a test setup in VMware.  You should be able to install it on VMware to test certain features.  The key for 6.1 will be to get the VMware requirements correct.  Here are the spec's that we use in our Lab testing environment for 6.1.5:
1 - vCPU
2Gb RAM
80Gb Harddrive
Virtual Machine version 7
RedHat Version 4 32-bit
Hope this helps!
-Brett Fritzsch
THANKS FOR THIS.
I HAVE MANAGED TO BOOT UP CUCM ON VMWARE. I GET TO THE END AND THEN GET THE MESSAGE - NO DRIVE FOUND. AN ERROR HAS OCCOURED, NO VALID DEVICES WERE FOUND ON WHICH TO CREATE NEW FILE SYSTEM PLEASE CHECK YOUR HARDWARE FOR THEW CAUSE OF THIS PROBLEM
Did you add a SCSI or IDE virtual HDD?
I always used IDE for 6.x releases...
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi, I use this recommendation and it work in Workstation VMware 7.0,
1 - vCPU
2Gb RAM
80Gb Harddrive IDE
THX a lot
HTH, please rate all useful posts and right answers.
