cisco unified ip phone 6921 registration
Hello friends,
i have a cisco unified ip phone 6921 but i can't register to a Elastix server... can you please give me step by step instructions how to do it... where should i  go to insert the username and the password ?
Thanks!
Hall of Fame Super Silver
You should probably be looking the "Elastix" guidelines and compatibility, as they should be providing the details if they approved this Cisco phone with their service.
HTH,
Chris
Yes but i don't know where in the phone i should insert the username and password. Can you please tell me wich software should i use to register the server.Thanks
Is the phone using SIP or SCCP firmware, first ensure it is SIP.
Chris
If this is the company you are talking about, I don't see Cisco phones as certified hardware:
http://www.elastix.org/index.php/en/product-information/certified-hardware.html
HTH,
Chris
Thanks for the answers if i upgrade the phone firmware to sip should that work?
How can i upgrade a cisco ip phone 6921 firmware ?
It would definielty need to be SIP to integrate with any 3rd party systems.
Chris
495
