Cisco Unified Mobile Communicator with UCM 6.1
I have a UCM 6.1 and a Cisco Unified Mobile Communicator installed on my Nokia phone, the Question: Is it possible to register the Cisco Unified mobile communicator with UCM 6.1 without CUMA 7.0
1 REPLY
Re: Cisco Unified Mobile Communicator with UCM 6.1
No, CUMC needs CUMA to work.
You can try to register it as a 3rd party sip or use this
Nokia Call Connect for Cisco
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6789/ps7290/ps10589/data_sheet_c78-567820.html
But CUMC without CUMA is not possible.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
149
