02-21-2012 12:59 AM - edited 03-16-2019 09:41 AM
How to add
phones..i mean how will be the connection .
I want to add 7925G wirless phones in 2901 cme
02-21-2012 06:14 AM
Same as any other phone type.
02-21-2012 06:18 AM
Is there any other Extra hardware required Required to add a wireless phones
02-21-2012 06:36 AM
One or more APs.
02-21-2012 06:39 AM
Ok so u mean if i want to add a wirless phones i need 2-3 wirless access
points for adding that i want to add 13 wirless phones
02-21-2012 06:42 AM
Depends on coverage you need to give, you will get a different number and types of APs.
Please remember to rate useful posts clicking on the stars below.
02-21-2012 06:17 AM
Are you asking how to get a wireles phone to register wirelessly or how to get CME to show the 7925G as a device?
I haven't worked with CME, but with CUCM, some phone types are not part of the default configuration and need to have their files uploaded before being recognized as a device type.
One of the engineers here has recently done this with the latest version of CME on a router. He downloaded the latest tar file from the Cisco website and installed it on the router and the 7925G was recognized.
Ven
02-21-2012 06:38 AM
For your information Ven.
The tar file only contains auxiliary files. It is actually not needed to register and get working a 7925, or any other phone type. That is different from CUCM.
02-21-2012 06:44 AM
is some body told me before no need ap for that ..
is it work with ap?or need any other specific harware to add a wireless
less phone
02-21-2012 07:17 AM
Excuse me but I've answered you before already:
A wireless phone needs a wireless AP to work.
It is as simple as that.
02-21-2012 03:44 PM
As Paolo said, for any wireless device, you nee Wireless AP.
Check Table 2 for different AP supported -
02-22-2012 12:27 AM
is it need a specific Ap model or whether can use this model "WAP4410N-G5
02-22-2012 01:18 AM
Are you the end user? I weould recommend you contact a reputable consultant or Cisco partner for you needs, otherwise it will be very difficult for you to get anything done.
02-22-2012 02:34 AM
Could u please tell me it need any specifc Ap model or?
could u please tell me wether
7925 G works with
WAP4410N-G5
01-03-2013 12:29 AM
Guys please help
7925g wil work with
WAP4410N or not
