Cisco Unified Wireless IP Phone 7925G
How to add
  phones..i mean how will be the connection .
I want to add 7925G wirless phones in 2901 cme
Hall of Fame Super Gold
Re: Cisco Unified Wireless IP Phone 7925G
Same as any other phone type.
Is there any other Extra hardware required Required to add a wireless phones
One or more APs.
Ok so u mean if i want to add a wirless phones i need 2-3 wirless access
points for adding that i want to add 13 wirless phones
Depends on coverage you need to give, you will get a different number and types of APs.
Please remember to rate useful posts clicking on the stars below.
Bronze
Are you asking how to get a wireles phone to register wirelessly or how to get CME to show the 7925G as a device?
I haven't worked with CME, but with CUCM, some phone types are not part of the default configuration and need to have their files uploaded before being recognized as a device type.
One of the engineers here has recently done this with the latest version of CME on a router.  He downloaded the latest tar file from the Cisco website and installed it on the router and the 7925G was recognized.
Ven
Ven Taylor
For your information Ven.
The tar file only contains auxiliary files. It is actually not needed to register and get working a 7925, or any other phone type. That is different from CUCM.
is some body told me before no need ap for that ..
is it work with ap?or need any other specific harware to add a wireless
less phone
Excuse me but I've answered you before already:
A wireless phone needs a wireless AP to work.
It is as simple as that.
As Paolo said, for any wireless device, you nee Wireless AP.
Check Table 2 for different AP supported -
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps9900/data_sheet_c78-504890.pdf
is it need a specific Ap model or whether can use this model "WAP4410N-G5
Are you the end user? I weould recommend you contact a reputable consultant or Cisco partner for you needs, otherwise it will be very difficult for you to get anything done.
Could u please tell me it need any specifc Ap model or?
could u please tell me wether
7925 G works with
WAP4410N-G5
Guys please help
7925g wil work with
WAP4410N or not
Bronze
According to the specifications, this AP is backward-compatible with B/G, so I don't see why it wouldn't work.
Ven Taylor
868
