06-29-2009 02:04 AM - edited 03-15-2019 06:44 PM
hi,
it is possible to install cisco unity 5.0 without Exchange ?
i don't need the notification, i need just configuring voice mail and Autoattendant ?
thanks
Solved! Go to Solution.
06-29-2009 03:02 AM
No, it's MANDATORY to have a message store.
Exchange or Domino, your choice.
java
if this helps, please rate
06-29-2009 03:02 AM
java
06-29-2009 03:09 AM
thank you java
