cisco unity 5.0
hi,
i try to integrate unity 5.0 with one cluster ( publisher(backup) and subsriber(primary)).
in the process of integration, when connection try to check voice ports, the process fail with subscriber end success with publisher.
schud i create voice port (wizard) just in the publisher or both publisher and subscriber. now i just make it in the publisher.
thanks
Re: cisco unity 5.0
All configuration you do on publisher only.
VM ports will be registered with publisher.
Re: cisco unity 5.0
thanks for your quick reply.
i have created : voice ports and pilot number and MWI like integration guide. and i can ping from unity server both publisher and subscriber. but always the unity can't check ports with subscriber( failed), is this a problem ?
when i press phone message button i don't hear anything.
Re: cisco unity 5.0
Try to call pilot number. If I remember correctly you will need VM profile to use with message button.
From subscriber CM administration page you should see ports registered on publisher.
rate if this help.
Re: cisco unity 5.0
Btw you should add line group, hunt list and hunt pilot with same number like your VM pilot.
Check this guide for more information: http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/integration/cucm_sccp/guide/cuintcucmskinny060.html
119
