12-03-2013 05:44 AM - edited 03-16-2019 08:40 PM
I wanted to have an automated attendant answer whenever someone dials my phone number so I setincoming calls to be directed to the voice mail extension 2500.
If i call from a cell phone on the pstn, or from an internal phone connected to fxs port to 2500, I do get the attendant "hello cisco unity messaging system.." and hear the options, but as soon I press 4 to get the directory listing or start to enter an extension number, the attendant unsuccessfully tries to connect me to an operator - "sorry operator is not available". However if i call 2500 from an internally ip phone the attendant works just fine and I can select the option to transfer to an extension or get someone in the directory.
Solved! Go to Solution.
12-03-2013 11:07 AM
If that's all you have it's not surprise it's not working (although nothing should work since there's no DP for 2500 there), there's no DTMF config there in the VOIP DP
Add this:
dtmf-relay h245-alphanumeric
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
12-03-2013 06:22 AM
no i need dtmf-relay on the voice router gateway?
12-03-2013 08:38 AM
Yes, that does sound like there's maybe a DTMF problem in your environment.
What protocol is being used?
java
12-03-2013 08:55 AM
i am new to voice.
the gateway router is set up as a h.323 in cucm.
the ip phones are using sccp. not sure if that helps
12-03-2013 10:07 AM
Post your inbound DPs
java
12-03-2013 10:38 AM
voice-port 2/0/0
connection plar opx 2500 //(fxo port directs incoming calls to the voicemail number 2500 for automated attendant)//
dial-peer voice 1101 pots
destination-pattern 1101 //fxs port
port 2/1/0
dial-peer voice 90 pots
description local calls //calls outgoing to pstn
destination-pattern .......
port 2/0/0
dial-peer voice 2000 voip
destination-pattern 5...
session target ipv4:192.168.1.60 //my cucm server
12-03-2013 11:07 AM
Add this:
java
12-03-2013 11:23 AM
it was supposed to be
destination-pattern 25..
i will try ur suggestion and let you know today. btw do i need to create a call handler ? I didn't. I'm just using the voicemail number that everyone dials in to check their voicemail (2500) as the autoattendant.
12-03-2013 11:32 AM
OK, that makes more sense.
Yes, you should use a separate DN, a CTI RP with CFA to VM, how to configure an AA in CUC has been discussed thoroughly before, do a quick search on CSC to get info on that.
java
