09-16-2014 03:45 AM - edited 03-17-2019 12:10 AM
Hi all,
I have the flowing scenario:
I am creating a call handler to for the service desk, where staff will dial 1000 then he/she will hear a welcome message and will be transferred directly to service desk without any input
Here is what I’ve done:
In CUCM:
In CUC:
Call are getting forwarded the hunt pilot and its ringing to all line group members but I can’t hear the greeting.
I know I am missing something so could you please help me with that.
Thank you in advance.
Solved! Go to Solution.
09-16-2014 04:35 AM
Hi.
Did you select "My personal recording" under "Callers Hear" on greeting setting?
Carlo
09-16-2014 05:40 AM
Can you please download remote port monitoring tool, call the 1000 and post the output?
http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/Remote%20Port%20Status%20Monitor%20Setup.exe
Carlo
09-17-2014 02:13 AM
I recently had a similar issue to this, when I looked into it i could see the greeting hadn't saved on CUC, it turned out to be a Java issue, there is a work around for it here;
http://www.cisco.com/c/en/us/support/docs/unified-communications/unity-connection/117497-probsol-unity-00.html
Richard
09-16-2014 04:35 AM
Hi.
Carlo
09-16-2014 04:54 AM
09-16-2014 05:40 AM
Carlo
09-16-2014 08:13 AM
Cant run it in windows 8.1 64 bit :(
09-16-2014 09:47 AM
Hi there,
+5 to my friend Carlo for his good ideas here :)
I would use 2 Call handlers to accomplish this. Use the first one for EXT 1000 where the greetings reside & can be easily changed and then use the "After greeting Action" to transfer to the second Call handler. On this one you can set it with no greeting recorded and use the transfer setting (as you noted) to route to the Hunt Group @ 2000.
Cheers!
Rob
09-17-2014 02:13 AM
Richard
