Community Member
Cisco unity connection 8.6.1 / VMware workstation 10.0
Downloaded the iso file UCSInstall_UCOS_8.6.1.20000-1.sgn.iso to install Cisco unity connection.
Unified Communications Manager / Cisco Unity Connection Updates-8.6(1a)
Installing the same in VM Ware workstation 10.0, but not getting the selection for unity connection. Its automatically installs CUCM 8.6.1.
Please let me know any specific vmware settings to install unity connection 8.6.1.
1 ACCEPTED SOLUTION
Purple
Hi, you mean to say that you
you mean to say that you do not get the option of Product Deployment Section showing
Cisco Call MAnager
regds,
aman
Purple
Cisco Call MAnager
regds,
aman
Community Member
  Yes you are absolutely
Yes you are absolutely right
You are not getting UCxN
You are not getting UCxN option because your VMware configuration is not complying with the minimum requirement to install Unity connection.
If you are not installing through OVA template then look at the VM configuration minimum requirement section of that particular version from the link shared by Aman.
Manish
Purple
Hi Nagarajan, Please find the
Hi Nagarajan,
Please find the link with similar issue
https://supportforums.cisco.com/discussion/11508416/unity-connection-86-not-showing-product-deployment-selection
regds,
aman
Purple
Hi, You can refer the link
You can refer the link but you should get option .
http://docwiki.cisco.com/wiki/Virtualization_for_Cisco_Unity_Connection#Notes_on_100_user_VM_configuration
regds,
aman
875
