Cisco Unity Connection 8.6.(2a)SU3 boot.bif required
Hi All,
I require "boot.bif" file for Cisco Unity Connection 8.6.(2a)SU3 to make the DVD as bootable.
Thank you in advance.
Sankar.
1 ACCEPTED SOLUTION
Hi Sankar.If you have any
Hi Sankar.
If you have any bootable image (even CUCM) you can generate it using EG. Ultraiso and than recreate it within a non-bootable image to make it bootable
Carlo
Please rate all helpful posts "The more you help the more you learn"
1 REPLY
Hi Sankar.
Carlo
95
