cisco unity connection 8.6 integration with microsoft exchange server( 2003)
Hi ,
Sorry for buzzing the forum with unity issues, but we are in the process of upgrading to the unity server 8.6 ( latest version ) from the current 4.2.x, and at the same time we would require some information on its integration with the microsoft exchange server -- 2003 , that has been configured at our end.
Would really appreciate if someone can guide on the  documentation part as we move to 8.6 coming monday !!!
Whatever level you reach getting better never stops -- Sachin Tendulkar
1 ACCEPTED SOLUTION
I'm assuming you're referring to single inbox, right??
Single Inbox in Cisco Unity Connection 8.5  and Later
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/connection/8x/design/guide/8xcucdg032.html
Unified Messaging Guide for Cisco Unity Connection  Release 8.5 and Later
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/connection/8x/unified_messaging/guide/85xcucumgx.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Thnx Jave..
3385
