Cisco Unity Connection 8.X - Read Voicemails using RSS Feed
Cisco Unity Connection has the RSS feed, which gives option for reading Voicemails using RSS Reader. However, when we try using it, the messages open in Windows media Player, and does not play the message.
Has anyone tried accessign voicemails using RSS reader and which is the best reader to access voice messages and playback.
thanks.
Hall of Fame Super Red
Hi there,
Just curious if you tried this setting
Allowing Insecure Connections to RSS Feeds
By default, Cisco Unity Connection only supports secure connections to the RSS feed, using SSL. Some RSS readers, such as Apple iTunes, do not support secure connections.
If you want to allow users to be able to use RSS readers that do not support secure connections, do the following procedure.
To Allow Insecure RSS Connections
Step 1 In Cisco Unity Connection Administration, expand System Settings > Advanced > RSS.
Step 2 On the RSS Configuration page, check the Allow Insecure RSS Connections check box.
Note that when you use an RSS reader that does not support secure connections, if this check box is checked, the username and password are transmitted unencrypted over the network.
Step 3 Click Save.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/administration/guide/7xcucsag170.html#wp1071041
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
Have enabled this value. and tested this already, still the same. I am using Internet Explorer 8 to view the RSS feed.
Thanks.
382
