Cisco Unity Connection 9 call handler "sorry" before the greeting
hello,
I need help with System Call Handler.  First time creating a call handler to play a different language other than English.
If I set the language to "Use System Default Language", the greeting plays perfectly.
However, when I set the language to play "(French) Canadian", I hear the "sorry" in French, then the recorded greeting.
I not sure what I am missing as this is my first time creating a system call handler playing a different language beside English.
Thanks in Advance.
Are you sure you recorded the greeting, as a greeting, and not as a recorded name??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
problem solved.
thanks
Hello,What was the resolution
What was the resolution for your issue? I am having a similar issue when using Spanish.
650
