10-04-2013 10:29 AM - edited 03-16-2019 07:42 PM
Until know I have been managing several CUCM+CUC Business Edition servers. In this case, the CUCM and CUC resided on the same physical system. Now we are in the stages of deploying a CUCM 9 Classic cluster (which has been done), CUPS (done) and the last step to set up and test prior to deployment is Unity Connection 9.
I have created Port Groups and Ports, and CUCM sees them registered. However, when I go into Import Users I can only select to import from LDAP. On my other systems I could select from Phone System so I could import valid End Users into Unity Connection.
Have I missed a config, or does Unity Connection 9 only allow you to sync or import via AXL or LDAP?
10-04-2013 11:00 AM
I resolved this. Just in case somebody else needs help with the same:
- Go to Phone System under Telephony Integrations
- Go to the desired Phone System
- Go to the Edit menu and select Cisco Unified Communications Manager AXL Servers
- Enter your CUCM details and configure the port. I used 443, but I think you can also use 8443 and 8080.
- Add more servers and define order
- Configure and username and password. In my case, I used a specific CUCM admin user for this task.
- Save
- Test each connection. You will get a message such as Test message successfully sent to AXL server CUCM:443 if successful.
Now when you go to Import Users PhoneSystem (or whatever you have called the Phone System integration under Telephony Integrations) will appear.
10-04-2013 11:12 AM
Hi Frank,
This should be available in Connection 9.x as well;
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/user_mac/guide/9xcucmac100.pdf
Cheers!
Rob
"Why do the best things always disappear "
- The Band
