Cisco Unity Connection 9.x In BE, Registered, but not working.
I installed CUCM 9.x cluster on Cisco BE6000 servers.
After than i deploy CUC 9.x cluster. On same hardware with CUCM.
I configured integration CUC with CUCM, Voice Mail Ports Registered.
But,
When i call to pilot number - phone suspends for 10 seconds, after show "defaulting to TFTP" message, and nothing happen.
When i call from phone to phone with enabled VM profile and forwarding to VM, after 5 seconds of calling (for example 5 second NOAN), CUCM answers than called number is no available, but this phrase cuted after 1 second.
Please, can you help me with troubleshoot this issue?
Everyone's tags (2)
1 ACCEPTED SOLUTION
Can you dial the VM pilot?Can
Can you dial a VM port?
java
if this helps, please rate
www.cisco.com/go/pdi
java
Problem with suspending was
Problem with suspending was solved, problem was with network connection, and "UCM is down" problem.
Now i can dial VMpilot, and VMport, and access CUC voice menu.
But,
When i dial a number with set up VM user, in the moment when called number must forward to a VM port, system says, that called number is not available.
I though that it might be a "Class of control" set up incorrect.
I checked that the CSS of the line, and forwarding CSS contains partitions with VMpilot and VMport. But it's not worked.
I can dial VMpilot, and access message box, but a can't forward incoming call to Voice Mail for leaving the message.
Jaime, thanks for showing me
Jaime, thanks for showing me direction.
Trouble was in VMpilot's CSS, i put in this CSS partition with local users, and it worked.
55
