Cisco Unity Connection 9.X Issue
Hi, I installed a Cisco Unity Connection 9.1.2.10000-10 and followed the procedure in order to make the integration with the CUCM, after finishing the integration I can dial the Voice Mail (from the voice mail buttom of the phones), make the customization of the profile, record the message, etc. But when dial to the phone number and the call is fwd to the Voice Mail, the message of the voice mail is a standard audio, and i cant leave a message.
Thanks in advance for any idea,
Everyone's tags (1)
What did you set the "Voice
What did you set the "Voice Mail Box Mask" to under the Voice Mail Profile"?
Yosh
HTH Regards, Yosh
Hi Yosh, I have nothing in
Hi Yosh, I have nothing in that field
Hall of Fame Super Silver
Nothing is OK if you do not
Nothing is OK if you do not need to change the extension, is this SCCP or SIP integration?
If SIP do you have " outbound diversion header" checked on the SIP trunk and "use external phone number mask" unchecked on the VM route pattern/route list?
It is SCCP Integration,Thanks
OK, use port monitor to see
OK, use port monitor to see what digits you are getting and what is occurring to the call:
http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/Help/Connection%20Remote%20Port%20Status%20Monitor.html
75
