Cisco Unity Connection 9.x server is not part of a cluster
I have a Unity server that was upgraded to 9.X from 7.X it was a single server now I need to make it a cluster and I cannot seem to make it work.
The install of the subscriber fails due to the Publisher being a single server, If I install the HA license will it work?
Help
VIP Purple
Hi Miket, The ordering guide
Hi Miket,
The ordering guide of Messaging says
There are no separate licenses for Secordary, or High Availability (HA) servers. Both the Primary and the
Secondary will register with a single ELM.
What error message u get while adding SUB?
regds,
aman
It says configured first node
It says configured first node is not a first node. . I added the subscriber in the publisher.
admin:show cuc cluster status
Server Name  Member ID  Server State  Internal State     Reason
omscuc01     0          Primary       Pri Single Server  Normal
Database replication is not active
admin:
I created the 9.x from scratch no issues,  When I was given the UNITY that was upgraded from 7.x I fail.
HA is free but don't you need to add it?
VIP Purple
Hi, While installing
While installing secondary/subscriber unity connection server, are you selecting First Node configuration as NO.
regds,
aman
Yes
Yes
VIP Purple
Can u share the output of
Can u share the output of utils service list from both unity conenction 9 servers[Pri/Sec]?
Have u added only Publisher in Product Instance in ELM?
regds,
aman
I have the Pub in ELM however
I have the Pub in ELM however I cannot get the second Unity server built thats the problem
admin:utils service list
Requesting service status, please wait...
System SSH [STARTED]
Cluster Manager [STARTED]
Service Manager is running
Getting list of all services
>> Return code = 0
A Cisco DB[STARTED]
A Cisco DB Replicator[STARTED]
Cisco AMC Service[STARTED]
Cisco Audit Event Service[STARTED]
Cisco CDP[STARTED]
Cisco CDP Agent[STARTED]
Cisco CallManager Admin[STARTED]
Cisco CallManager Serviceability[STARTED]
Cisco CallManager Serviceability RTMT[STARTED]
Cisco Certificate Change Notification[STARTED]
Cisco Certificate Expiry Monitor[STARTED]
Cisco DRF Local[STARTED]
Cisco DRF Master[STARTED]
Cisco Database Layer Monitor[STARTED]
Cisco ELM Admin[STARTED]
Cisco ELM Client Service[STARTED]
Cisco ELM DB[STARTED]
Cisco ELM Server[STARTED]
Cisco Log Partition Monitoring Tool[STARTED]
Cisco RIS Data Collector[STARTED]
Cisco RTMT Reporter Servlet[STARTED]
Cisco Syslog Agent[STARTED]
Cisco Tomcat[STARTED]
Cisco Tomcat Stats Servlet[STARTED]
Cisco Trace Collection Service[STARTED]
Cisco Trace Collection Servlet[STARTED]
Connection Access Layer[STARTED]
Connection Administration[STARTED]
Connection Branch Sync Service[STARTED]
Connection CM Database Event Listener[STARTED]
Connection Conversation Manager[STARTED]
Connection DB[STARTED]
Connection DB Event Publisher[STARTED]
Connection Database Proxy[STARTED]
Connection Diagnostic Portal Service[STARTED]
Connection Digital Networking Replication Agent[STOPPED]  Component is not running
Connection Directory Feeder[STARTED]
Connection File Syncer[STARTED]
Connection Groupware Caching Service[STARTED]
Connection IMAP Server[STARTED]
Connection Inbox RSS Feed[STARTED]
Connection Integrated Mailbox Configuration[STARTED]
Connection Jetty[STARTED]
Connection License Manager Server[STARTED]
Connection Mailbox Sync[STARTED]
Connection Message Event Service[STARTED]
Connection Message Transfer Agent[STARTED]
Connection Mixer[STARTED]
Connection Notifier[STARTED]
Connection Personal Communication Assistant[STARTED]
Connection REST Service[STARTED]
Connection Realtime Monitoring APIs[STARTED]
Connection Reports Data Harvester[STARTED]
Connection SMTP Server[STARTED]
Connection SNMP Agent[STARTED]
Connection Server Role Manager[STARTED]
Connection Serviceability[STARTED]
Connection SpeechView Processor[STARTED]
Connection System Agent[STARTED]
Connection Voice Mail Web Service[STARTED]
Connection Voice Recognition Transport[STARTED]
Connection Voice Recognizer[STARTED]
Host Resources Agent[STARTED]
MIB2 Agent[STARTED]
Platform Administrative Web Service[STARTED]
SNMP Master Agent[STARTED]
SOAP -Log Collection APIs[STARTED]
SOAP -Performance Monitoring APIs[STARTED]
SOAP -Real-Time Service APIs[STARTED]
System Application Agent[STARTED]
Cisco DirSync[STOPPED]  Service Not Activated
Cisco ELM Resource API[STOPPED]  Service Not Activated
Cisco Serviceability Reporter[STOPPED]  Service Not Activated
Connection Exchange Notification Web Service[STOPPED]  Service Not Activated
Primary Node =true
admin:
VIP Purple
Bit confused . I was refering
Bit confused .
I was refering the licenses portion under th elink
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/9x/cluster_administration/guide/9xcuccagx.pdf
which says that
A Cisco Unity Connection cluster requires a license for each Connection server. The license that has the MAC address of the publisher server must be installed on the publisher server. The license that has the MAC address of the subscriber server must be installed on the subscriber server.
can u look into this ? Lastly,what is CUCM version u are using.
regds,
aman
VIP Purple
Hi Miket, Is your issue
Hi Miket,
Is your issue resolved ?
regds,
amn
Sorry yes it is resolved.
VIP Purple
Hi Miket,If u do not mind,
Hi Miket,
If u do not mind, can u brief on how it resolved ?
regds,
aman
The database replication
The database replication command was from the first node
355
