11-06-2014 06:27 AM - edited 03-17-2019 12:49 AM
Hi all,
I have a unity connection and my exchange server, I have it configured to get the voice mails in my email box, but the issue is I can't sync at the moment I delete the files.
E.G: If I delete the files in the Exchange I want them to be deleted in the Unity.
Thanks.
11-06-2014 07:21 AM
Did you configure UM?? Or just accept and relay??
11-06-2014 09:06 AM
Hello Jaime,
What will the difference be between each other?
Thanks.
11-06-2014 09:06 AM
Read here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/unified_messaging/guide/85xcucumgx.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/design/guide/8xcucdgx/8xcucdg032.html
If all you have is relay, what you're seeing is completely expected, they won't sync at all.
11-06-2014 09:19 AM
This will be for the version 7.1.3
11-06-2014 09:27 AM
Then relay is all you can get, and there is no way to sync between the VM in CUC and Exchange, what you're seeing, is the expected behavior.
CUC will just FW the message to whatever recipient you have configured, and no longer cares what happens to it.
11-06-2014 09:31 AM
With the version I have 7.1.3 I dont see any other option, to fix this.
Thanks.
