Cisco Unity Connection calls transfered to opening greeting
Hi guys,
I am installing a new CUC 10 server using SIP integration with CUCM.
When i press the message button from the ip phone i am redirected to sign in using my pin and everything works as expected.
The problem is when i forward the calls to voicemail, when other internal or external callers try to call my number , they hear opening greeting instead of my personal voicemail message.
Any help is much appreciated
1 ACCEPTED SOLUTION
Make sure you have
Make sure you have Redirecting Diversion Header Delivery - Outbound on the SIP trunk in UCM.
Please rate useful posts.
Make sure you have
Thank you very much George
Thank you very much George for you help.
That did the trick :)
Best Regards
127
