Cisco Unity Connection CUC Roles and Reset PIN Privilege
milkboy33
Hello Everyone,
   Question:
   Which other roles does a user who has the Helpdesk role be able to change their password/PIN? For example we know a Helpdesk role user cannot change the password of other Helpdesk role users nor System Admin role users.
Roles in CUC 8.6:
Audio Text Admin
Audit Admin
Greeting Admin
Help Desk Admin
Mailbox Access Delegate
Remote Admin
System Admin
Technician
User Admin
Thanks!
Tom
18 Replies 18
8.6.2ES44.22900-44
The version I have tested with is 8.6.1.20006-2 and you're just 1 update away from the latest 8.6 version. I would have to assume that this is not a bug but instead it's how Cisco wants it to work. I would reach out to TAC and see if there is a way to either, modify the HD Admin role or provide you with a special update to change this functionality.
Yosh
HTH Regards, Yosh
Thank you guys very much. I will contact TAC next.
Hello Tom,
When you talk with TAC, keep in mind this bug:
https://tools.cisco.com/bugsearch/bug/CSCtd45141/?reffering_site=dumpcr
They will probably bring it up.
