Cisco Unity Connection greeting file upload issue
I have Cisco unity connection 2.0.1 version.
When I upload greeting wav file, browser shows uploaded susccesfully. But It is not uploading greeting wav file. It is playing previous file.
But When I record through phone, everything working fine.
It could be java issue, we have degrated java and tried with 1.5 version also 1.6 version but problem is same.
I tried with IE, Firefox, chrome and all browser same issue.
At Java Console, I am getting below issue,
2014-02-26 11:58:12:859 [MPThread[5]-Upload-UMS-Stream] ERROR com.cisco.unity.mediamaster.httpclient.utility.UploadByteArrayCache::sendRequest( HTTPClient-MultipartPostMethod ) - out - Upload failed with exception: sun.security.validator.ValidatorException: No trusted certificate found, Time Elapsed: 16, Exception Class: javax.net.ssl.SSLHandshakeException
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: No trusted certificate found
    at com.sun.net.ssl.internal.ssl.Alerts.getSSLException(Unknown Source)
    at com.sun.net.ssl.internal.ssl.SSLSocketImpl.fatal(Unknown Source)
    at com.sun.net.ssl.internal.ssl.Handshaker.fatalSE(Unknown Source)
    at com.sun.net.ssl.internal.ssl.ClientHandshaker.serverCertificate(Unknown Source)
    at com.sun.net.ssl.internal.ssl.ClientHandshaker.processMessage(Unknown Source)
    at com.sun.net.ssl.internal.ssl.Handshaker.processLoop(Unknown Source)
    at com.sun.net.ssl.internal.ssl.Handshaker.process_record(Unknown Source)
    at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(Unknown Source)
    at com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)
    at com.sun.net.ssl.internal.ssl.SSLSocketImpl.writeRecord(Unknown Source)
    at com.sun.net.ssl.internal.ssl.AppOutputStream.write(Unknown Source)
    at org.apache.commons.httpclient.HttpConnection$WrappedOutputStream.write(HttpConnection.java:1360)
    at java.io.BufferedOutputStream.flushBuffer(Unknown Source)
    at java.io.BufferedOutputStream.flush(Unknown Source)
    at org.apache.commons.httpclient.HttpConnection.flushRequestOutputStream(HttpConnection.java:790)
    at org.apache.commons.httpclient.HttpMethodBase.writeRequest(HttpMethodBase.java:2271)
    at org.apache.commons.httpclient.HttpMethodBase.processRequest(HttpMethodBase.java:2651)
    at org.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.java:1087)
    at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:643)
    at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:497)
    at com.cisco.unity.mediamaster.httpclient.utility.UploadByteArrayCache.sendRequest(UploadByteArrayCache.java:331)
    at com.cisco.unity.mediamaster.httpclient.utility.UploadByteArrayCache.sendMultipartPostRequest(UploadByteArrayCache.java:279)
    at com.cisco.unity.mediamaster.ums.thread.UploadMPThread.uploadStream(UploadMPThread.java:493)
    at com.cisco.unity.mediamaster.ums.thread.UploadMPThread.uploadParts(UploadMPThread.java:425)
    at com.cisco.unity.mediamaster.ums.thread.UploadMPThread.run(UploadMPThread.java:380)
    at java.lang.Thread.run(Unknown Source)
Caused by: sun.security.validator.ValidatorException: No trusted certificate found
    at sun.security.validator.SimpleValidator.buildTrustedChain(Unknown Source)
    at sun.security.validator.SimpleValidator.engineValidate(Unknown Source)
    at sun.security.validator.Validator.validate(Unknown Source)
    at com.sun.net.ssl.internal.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source)
    at com.cisco.unity.mediamaster.httpclient.protocol.SelfSignedCertX509TrustManager.checkServerTrusted(SelfSignedCertX509TrustManager.java:171)
    at com.sun.net.ssl.internal.ssl.JsseX509TrustManager.checkServerTrusted(Unknown Source)
    ... 23 more
2014-02-26 11:58:12:859 [MPThread[5]-Upload-UMS-Stream] ERROR com.cisco.unity.mediamaster.httpclient.utility.UploadByteArrayCache::sendMultipartPostRequest() - out - Error while sending MultipartPostMethod - EXCEPTION
2014-02-26 11:58:12:859 [MPThread[5]-Upload-UMS-Stream] WARN  com.cisco.unity.mediamaster.ums.thread.UploadMPThread::run() - Send data failed for part: 0
2014-02-26 11:58:13:140 [Thread-7] WARN  com.cisco.unity.mediamaster.ums.UMSController.uploadTargets() - Upload Failed - Resetting Stream status to: 3
2014-02-26 11:58:13:140 [Thread-7] WARN  com.cisco.unity.mediamaster.ums.UMSController.uploadTargets() - out - Upload Failed
2014-02-26 11:58:13:140 [Thread-7] WARN  com.cisco.unity.mediamaster.MMApplet.saveData() - out - Upload Performed: false
2014-02-26 11:58:13:593 [thread applet-com.cisco.unity.mediamaster.MMApplet.class] NOLEV com.cisco.unity.mediamaster.MMApplet.stop() - in
2014-02-26 11:58:13:609 [thread applet-com.cisco.unity.mediamaster.MMApplet.class] NOLEV com.cisco.unity.mediamaster.MMApplet.stop() - out
2014-02-26 11:58:13:609 [thread applet-com.cisco.unity.mediamaster.MMApplet.class] NOLEV com.cisco.unity.mediamaster.MMApplet.destroy() - in
2014-02-26 11:58:13:609 [thread applet-com.cisco.unity.mediamaster.MMApplet.class] NOLEV com.cisco.unity.mediamaster.MMApplet.destroy() - out
Pls. suggest
Everyone's tags (1)
Check your certs for the server, I had similar problems when the certs were expired.
This solution specified at
This solution specified at this blogspot site worked for me.
"Attempting to save an uploaded recording in the Media Master applet results in an error "Failed to record name", the workaround is to select "use phone" for playback (see screenshot below), upload the recording, play it & then saving works; not playing the recording or playing it through the computer fails."
http://ccnp-v.blogspot.com/2015/02/unity-connection-connection-failed-to.html
1240
