CISCO unity Connection Uers
Hi everyone,
I have  question
i have cucm 8.5 and integrated with  cisco unity connection 9 and i am attempting to create an auto-attendant  where a caller will dial a DID and be greeted with a message and then given the option to press 0 for operation , or press the extension for users
I have in cisco unity 300 user to use auto-attendant , but i notice my license is just for 25 user to use the voice mail and the other 275 is violate now,
i don't know i need to buy anew license for all users or there another option to fix this issue
and if i need to buy license what license to buy and how much  i found their two type for license.
thank you
1 ACCEPTED SOLUTION
It sounds like you just want
It sounds like you just want a Single Auto Attendant that answers for all the DIDs, is that correct?
If so, you will need to set up:
Unity:
System Call Handler, with the options you require - assign an extension.
CUCM:
A voicemail profile that sends the extension over to Unity ( if 4 digit extension, use XXXX).
CTI RP for the new Call Handler Extension, using the new vm profile you just made
Update user Extensions to CFNA to the new Call Handler extension.
-Kevin P.
Unity:
CUCM:
-Kevin P.
Thank you for replayno not
no not what I mean
 we have like 300  users  in cisco unity and every user  have extension from 4 dig XXXX
my questions is  if i have 300 users for auto-attendant in cisco unity that mean I need licences for 300 users and what type of license and how much ?
If you have 300 user
If you have 300 user mailboxes, you'll need 300 licenses.  The user's that don't need a mailbox, you can do a call handler for to not eat a license.
In 8.5 you license ports, HA, and Users.  The system call handlers (AAs) are not licensed.
I would contact your cisco partner to order, UNITYCN8-USR.
Kevin P.
Hi kevin ,Thank you for
Hi kevin ,
i checked the BOM and i found i have this
UCM-9X-ENH-UCL  BE6K UCM 9X Enhanced User Connect License
and i have
BE6K-UCL-ENH   Cisco Business Edition 6000 - Ehanced User Connect License
and
UCN-9X-VM-UCL   BE6K - Unity Cn 9X - Voicemail license
what the differnt and wich one i can use for user in unity for auto-attendant
Ah you're on 9x, so ya you'll
Ah you're on 9x, so ya you'll need to match this license count to your actual users:
BE6K-UCL-VM
I would advise you reach out to your partner to confirm with exactly what you have.  It will likely save you in the long run to have someone familiar with your environment advise on licensing.
you mean UCN-9X-VM-UCL
you mean
UCN-9X-VM-UCL
I meant what I said :), UCN
I meant what I said :), UCN-9X-VM-UCL is EoS, I posted the current part number replacement for that.
You have cm 8.5 CM but Be6k licensing for Unity?  What I posted is the additional voicemail user licensing for Be6k, so I suggest you reach out to your partner to get clarification.
Thank you for replay Im just
Im just wondering how much this license for one user.
,Hi Kevin;can you please tell
Hi Kevin;
can you please tell me if you Know ,can you put user extension in Cisco unity without voice mail .
thank you
Well you can configure a User
Well you can configure a User with mailbox to not take a message under the greeting you will see the option for what to do after greeting is played.  It's set to take message.
If it isn't a user, you can set up a System Call Handler with an extension, and you can configure that handler ot play greetings with caller input options as you see fit - no mailbox.  However you can allow a call handler to take a message and place it in a user's mailbox.
Hi Kevin;thank you for replay
Hi Kevin;
​finally it work fine for my case .
its just transfer check box in greeting .
174
