Cisco Unity Connection Voice Mail to e-mail
Mario Musquiz
Hi all
Im trying to make the voicemail get to the e-mail of each user, i add a smtp server on System Settings>>SMTP Configuration>>Smart Host, then i go to the users in Edit>>Edit Message Actions>>Voicemail>>Accept and Relay the Message,   Relay Address>>(email of user)
Whit this the Unity is not sending email notificacions so i added the next configuration un the User Edit>>Notification Devices>>STMP>>Enable and on the To** i added the user email again, whit this the email is still not been sent.
What am i missing here ? the SMTP server does allow sending email whitout Authentication i try in my laptop and works.
Can someone help me here ?
Amine Nouasri
Level 3
Level 3
It could be that the SMTP relay not accepting messages from Unity Connection. There is a cmd from the CLI to test outgoing emails: run cuc smtptest <email address>. I would look at the traces related to SMTP in RTMT and get the error code when it fails sending an email out.
Please rate helpful answers!
I try it and i get the following error
ACE_File_Lock::ACE_File_Lock: Permission denied /dev/shm/CCM_GENstatusLock_0
A test email with the subject 'Cisco Connection Test Message' has been sent to mmusquiz@gn-corp.com.
Please check the destination email account and reply to the message.
Waiting for reply... (ctrl-C to abort)
SMTP Test FAILED: Configuration error: The Incoming SMTP address in SpeechView settings is missing or invalid.
then, look at the RTMT traces. It would definetly tell the error message when it fails. I believe you would have to look at the Connection Conversation Manager:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/troubleshooting/guide/8xcuctsgx/8xcuctsg010.html#wp1085548
Hope this help!
