Cisco Unity Connection with LDAP Problem
I have a CUCM and Cisco Unity and an LDAP Server 2008,
When I configure CUCM with LDAP, users are imported, but when I did the same method for integrating Cisco Unity with ldap does not work, when I click "Import User" via LDAP I find a user who call "Token_User_8b191a06-5041-4b41-bd5f-0575fde674e3" without extension, and no user is imported
Unity Version : 9.0
CUCM Version : 9.0
LDAP : Windows 2008 Server
Younes CHAFI.
  • IP Telephony
1 ACCEPTED SOLUTION
VIP Super Bronze
Please attached the full capture..I cant make anything of the screen capture
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi Younis
1- Regarding AD 2008 , did you follow Cisco guide as the below:-
**When you are configuring Connection for Microsoft Active Directory 2008 Lightweight Directory Services, select
Microsoft Active Directory Application
2- Did you try  to delete the LDAP integration and re-create it again?.
Please rate all useful information
Re: Cisco Unity Connection with LDAP Problem
I followed the guide and I selected Microsoft Active Directory
and I deleted/recreated the integration but the same problem
Younes CHAFI.
VIP Super Bronze
Can you post a screen shot of your LDAP config, including the search base..Do you have the same search base configured as with CUCM?
Yes, it is the same configuration in CUCM,
I configure CUCM with LDAP, users are imported.
attached the error message and the LDAP config
VIP Super Bronze
try this for your search base,
ou=users,dc=lab,dc=ma
Hi ,
does not work, I get an error message
"directory.error.userbase"
VIP Super Bronze
What is your setup in AD? Do you have a container called users?
Can you try this again..
user search base dc=lab,dc=ma
here is my LDAP configuration,
I tried this syntax cn=Users,dc=lab,dc=ma , but without result
Younes CHAFI.
VIP Super Bronze
Users are usuallually in Orbanisation units hence referneced by OU not CN (containers)
Try and use the whole domain,  dc=lab, dc=ma
1439
